Scaling is not working in Premiere Pro 2023
  • January 4, 2023
  • 2631 views
Dear all,
I have an issue with Premiere Pro that my image cannot scale with an anchor point when I use the scale function. (it doesn't with when the anchor point is in the centre as well I've tested it)
I've looked through the discussion and youtube tutorial from the past regarding the same issue, the method provided were 1) changing a bit in the position with the same keyframes and 2) rendering in and out from the sequence menu. However, both methods don't work for me. I have also reinstalled premiere pro which doesn't work as well. The keyframes are linear so I don't think it's the bezier issue that the other posts mentioned.
Does anyone know if is there another way I can solve the issues?
Thank you.
chrish15304456
Try going to Project Settings > General > then change the Renderer option.
Hi, Karen
Can you let us know info about your computer system and media? What camera shot the footage? Is it 4K?
Sounds odd, Karen. Is the clip selected in the Timeline?
Hi Kevin,
Yes, the clip is selected.
I later found the issue is that the scale cannot be used with the image file but is okay with the video file. So I remake the video clip and somehow dealt with it.
But it is still strange to me that why premier pro is not dealing with image file cause I feel like it is a common use function.
Karen
Hi, Karen,
What are the specs of the image?
kglad
p.s. i don't think the adobe website, and forums in particular, are easy to navigate, so don't spend a lot of time searching that forum list. do your best and we'll move the post if it helps you get responses.
<moved from using the community>
