Scaling is not working in Premiere Pro 2023
  • January 4, 2023
  • 2631 views
Dear all,
I have an issue with Premiere Pro that my image cannot scale with an anchor point when I use the scale function. (it doesn't with when the anchor point is in the centre as well I've tested it)
I've looked through the discussion and youtube tutorial from the past regarding the same issue, the method provided were 1) changing a bit in the position with the same keyframes and 2) rendering in and out from the sequence menu. However, both methods don't work for me. I have also reinstalled premiere pro which doesn't work as well. The keyframes are linear so I don't think it's the bezier issue that the other posts mentioned.
Does anyone know if is there another way I can solve the issues?
Thank you.
chrish15304456
Try going to Project Settings > General > then change the Renderer option.
Hi, Karen
Can you let us know info about your computer system and media? What camera shot the footage? Is it 4K?
Sounds odd, Karen. Is the clip selected in the Timeline?
Karen JRAuthor
Hi, Karen,
What are the specs of the image?
Sorry didn't notice you replied!
It was 3840x2160. It is an image I cropped from a 4K resolution video.
Karen
kglad
p.s. i don't think the adobe website, and forums in particular, are easy to navigate, so don't spend a lot of time searching that forum list. do your best and we'll move the post if it helps you get responses.
<moved from using the community>
