Screen Tearing Issues in Premiere Pro
  • April 25, 2020
  • 2595 views
I'm having pretty bad screen tearing issues in all video panels when I view files on Premire. This hasn't been happening with any of my other media players on my computer. My laptop is a Lenovo Ideapad 720s with a NVidia GTX 1050 Ti graphics card. Tried going into the NVidia control panel and playing with vsync settings but it doesn't seem to be fixing anything. Any ideas?
Videographer Suxrob
I am writing through a Google translator, I apologize for grammatical errors, I have been looking for an answer to this problem (i.e. premiere proda frame tear problem) for 2 years, my advice to you is to install Adobe Premiere Pro 15.1 ONLY I do and I'm sure there will be no problem like any tearing in the frames only in version 15.1!
By the way, one more thing, you can try this method, this method (https://www.youtube.com/watch?v=zvjy4lAE1iA ) worked for me, but working in OpenCL without being a fast DirectX is a bit difficult for me. Please contact visionicloud@gmail.com for any help I am happy to help you remotely (via TeamViewer)!
have u found a fix because mine is experiencing the same problem.
Averdahl
quote
By @Yvng Chuck
Go to Nvidias Control Panel set Vertical sync to On.
Averdahl
Unfortunatly to no avail this strat hasn't work aswell... even regular footage that isnt drone footage also has this same screen tearing, time to contact Adobe's CEO for a lawsuit... lol
quote
By @Yvng Chuck
Does it work if you go to File > Project Settings > General and set the Renderer to Software Only?
