Dierenwinkel Doc
Scrolling out too fast zooms in fully on timeline
  • March 7, 2023
  • 19 replies
  • 4124 views
When you zoom out in the timeline (too fast appearently according to premiere) It snaps back to fully zoomed in. This is a very very very annoying issue that i deal with on a daily basis.
https://i.gyazo.com/c432821ec6457f2d4c4b5808376c1c75.mp4
Look at the bottom bar you can really see the zoom in this happens when i just scroll out a bit fast i really have to scroll really slowly in order for it not to completely zoom in.
Expected result: For it not to zoom in like crazy when i try to zoom out.
M1 Max, Premiere 23.2.0 build 69 (nice)
Much love,
Dierenwinkel
Kevin-Monahan
Are you still experiencing this issue, @Dierenwinkel Doc? Let the team know. I'll move this report to the Discussions forum while we await your response.
Aiden Soave
hey @Kevin-Monahan just letting you know i also experience this bug currently even on most up to date beta builds
Daan-Jesse
Any solution? Still have this issue on my Mac's....
eddiekingson
Same problem here.
On both the 2023 and 2024 versions of Premiere.
I have to zoom very very slowly or else it snaps to fully zoomed in.
Apple M2 max
Premiere Version 23.6.4 (Build 2)
Premiere Version 24.2.1 (Build 2)
eddiekingson
Issue fixed on its own. Zoom works again on both versions. Might have been de OS or premiere update, I'm not sure.
macOS Sonoma 14.5 (M2 max)
Premiere Version 23.6.5
Premiere Version 24.4.1
Want to report this still happens to me.  So it's not fixed.
Same here. Have had this for a while now, can't remember the first time I had this but it's likely on the later 2022-2023 versions. It's a real time (and flow) waster
Hi, @JohnColombo17100380 !
I have the same issue.
When I try to zoom out, th etimeline just randomly jumps back to fully zoomed in.
I have an ordinary Hama MW-500 mouse, but it works fine with an older version of Premiere on my other laptop.
Win 11, Premiere 23.6.0 build 65
JohnColombo17100380
Hi @Dierenwinkel Doc,
I will have to ask my contacts on the Premiere team, as I'm on the After Effects team.
Cheers,
- John, After Effects Engineering Team
Dierenwinkel Doc
Doesn't fix the issue sadly, also I'm on Mac
Harold Silva
Hola buenos días, lo que te recomiendo es reiniciar el programa y mantener presionadas las teclas CTRL + SHIFT+ALT y ejecutar el programa estro restaura la configuración inicial del software.
Eso debiera solucionar el problema.
Saludos
Harold Silva B.
Dierenwinkel Doc
@JohnColombo17100380 Can u please look into this? ❤️
