SirBenitoIV
Second monitor / Playback not working / MSI P65 Creator
  • May 3, 2019
  • 1232 views
Hello everyone
I recently bought a MSI P65 Creator. But playback won't work if I use a second monitor. At first it was working, but when I select footage to preview before I put it on my timeline it freezes and I have to restart Premiere.
Is this because my second monitor is connected to my NVIDIA Graphic Card while the main monitor is using the Intel Graphics?
And if so, is there a way to get around this?
I didn't had this problem on my previous laptop.
My laptop specs:
Intel Core i7-8750H
NVIDIA GeForce GTX 1060 (6GB)
RAM: 16GB (DDR4)
I have the same Problem now with my brandnew p65 creator with the GTX 1070.
Any Solutions?
There is a bug in the current release concerning Transmit Out and apparently occasionally simple second monitor hookups. Although it's more normally affecting those like me who wish to control which of the three monitors Transmit goes to, and Pr disagrees. Passive resistant, allows you to check a monitor but as you close the dialog, simply ignores your action and reselects the other monitor.
How do you have the OS set to use that second monitor ... extend onto it, see as "one" space, what?
Are you transferring the complete UI over to the second monitor?
Are you working some parts of Pr on the laptop, some on the second monitor?
SirBenitoIV
It's extend onto it.
Normally I transfer the entire UI over to the second monitor and I move the playback panel to my main monitor.
I also tried using Premiere Pro 2018.
Wes Howell
Adobe Employee
Adobe Employee
May 7, 2019
Some laptops are setup so that the onboard GPU isn't "de-selectable" at least for the laptop screen or in general. Pr sometimes has difficulty working with the paired GPU setup. Sadly ...
Wes Howell​ ... any further help on this?
Not sure on this one as I don't have access to that hardware.
It may be worth looking into seeing if the Intel GPU can be disabled in the BIOS?
Otherwise, I would recommend pinging Adobe support on this one.
Wes
