Setting workarea in and out of a Sequence with Automation Blocks (aescript plugin)
  • December 1, 2023
  • 4 replies
  • 1282 views
I would like to set the workarea (render-area) of a Sequence to timecode in: X and out: Y.
It looks like the set attribute [   ]  of sequence block doesn't provide the workarea as an option.
Is there another way to do it, or, can it be implemented?
In ExtendScript I would expect to be implemented:
seqItem.isWorkAreaEnabled() - check if there is a workarea
seqItem.setWorkAreaEnabled(true) - enable or disable a sequence's workarea
seqItem.setWorkAreaInPoint() - set sequence workarea inpoint
seqItem.setWorkAreaOutPoint() - set sequence workarea outpoint
seqItem.getWorkAreaInPointAsTime() - get sequence workarea inpoint
 seqItem.getWorkAreaOutPointAsTime()  - get sequence workarea outpoint
As also found here:  https://github.com/Adobe-CEP/Samples/blob/master/PProPanel/jsx/PPRO/Premiere.jsx
Correct answer Mathias Moehl
The Set Property of Sequence block of Automation Blocks 1.1.000 now actually supports properties "workarea in", "workarea out" and "workarea enabled". But note that these functions don't work reliably in Pr's scripting API (and I guess that's also the reason why they are not documented). See the API bug infos here:
https://docs.mamoworld.com/automation-blocks/block-reference/prSequence#work-area-enabled--in-point--out-point
Mathias Moehl
Hello, the link mentions bugs in setting in and out point programmatically.
In my case, I just read them programmatically, so it is reliable enough.
Thanks!
Jonathan-David
Mathias Moehl
Automation Blocks does not support the workarea, yet. You can set in/out but not the work area. I have just put it on my list of feature requests. 🙂
🙏 Thanks a lot. Getting and setting the work area is going to make the Send-to-mediaencoder-block more useful. Can't wait to use it. 🙂
Mathias Moehl
You are welcome :.-)
In the Send to Media Encoder Block, the "range" option can be set to "in and out point". So this would be the best workflow for now, since in and out point can be set with Automation Blocks.
Hi Bruce,
Thanks for answering the question I didn't ask. 🙂
Actually, I asked Mathias how to do this with "Automation Blocks" (it's a Première Pro plugin), not how to do it with ExtendScript. I even had the same PProPanel URL in my post. By the way, did you guys already solved the ExtrendScrip bug DVAPR-4239719, regarding this matter?
Bruce Bullis
I have no idea where that Scratch-like UI in your screenshots is coming from, but here's PProPanel, setting the work area:
 https://github.com/Adobe-CEP/Samples/blob/e60d6a22ef44d8eb4cca3904c35a0c050576b697/PProPanel/jsx/PPRO/Premiere.jsx#L2571
