wheretfismyvape
Shure SM7B not picked up in Premiere Pro 2026?
  • May 30, 2026
  • 63 views
I’ve recently updated Premiere Pro to v 26.2.2, and now my Shure SM7b mic is not being recognized. The mic is connected to a Focusrite Solo via XLR, then to pc with USB. I have tried connecting the audio interface to every USB port on my pc to start, yet the issue remains. Audio interface has phantom power enabled, and audio is picked up in Windows settings, discord, Google Gemini, etc. Confirmed default input/outputs are set correctly. I have attempted rolling back to previous versions of Premiere, re-installing mic drivers, creating new sequences, creating mono audio tracks, changing Audio Hardware input/output from system default to actual device, checking for System updates (Acer pc), restarting computer, disconnecting and reconnecting all cables, testing mic in a separate project, ensuring the mic is set as default in Control Panel, allowed by Privacy & Security in Settings, and the list goes on (see screenshots for applicable settings). Any advice/assistance would be great. Thanks!
    Correct answer John T Smith
    Sound Driver http://www.asio4all.com/ link
    I would try an ASIO driver rather than the MME if you have that option.
    John T Smith
    John T SmithCommunity ExpertCorrect answer
    wheretfismyvape
    Installed, and confirmed issue is resolved. Someone get Richard M Knight & John T Smith a reward 👏
    I’m assuming this is to do a voice-over on a track on a sequence?
    If so ... have you tried default input to none? I don’t see that listed in your post. At that point, Premiere simply uses the system setting and it is normally the best choice for audio input in Premiere.
