Some color management features not supported
  • October 15, 2024
  • 2958 views
Now that V25.0 is released, I've decided to stop using the beta V25.1 and continue working on a beta project in V25.0. However, when I open it, I get a dialog saying, "Some color management features not supported." If I dismiss the dialog by clicking "Continue in this version" the project colors look fine. So to my question: Is there anything I can change while the project is open in V25.1 (beta) to prepare it for compatibility in V25.0?
In other words: What are the "color management features" that are available in the beta that are not available in 25.0, and can those features be avoided by choosing compatible settings?
I had the same problem. I found the solution.
1) Open the project in premiere pro (usual version, not beta)
2) Pres "open project in this version"
3) Create new sequence
4) Copy all elements from old sequence to new sequence
5) Delete old sequence created in beta
6) Seve project
Hello, @the outward spiral,
Thanks for the note.
quote
By @the outward spiral
Can't you just update to 25.1 and open the 25.1 Beta project there? Let me know if that is a workable solution.
Hi Kevin.
Thanks for the suggestion.
Unfortunately, version 25.1.0 (build 73) hasn't caught up with the beta's color management, so the warning persists.
mc_finney
Yah i get this message every time I open a Beta project in 2025 despite having both my Beta and my 2025 applications fully updated - it still keeps telling me i need to update.
Here this message comes in the newest version of premirer. I don´t now why.
