Sony a7siii 4k 120fps 4222 10 bit playback issues in premier
  • December 18, 2020
  • 7344 views
I am on the newest mac book pro fully spec'd out and having issues playing back Sony a7siii 4k 120fps 4222 10 bit.
When I shoot 420 10 bit that footage plays back fine.
Will there be a fix for this soon or is anyoen else having issues?
Trying to create proxies but dont want to add that to my workflow.
Kevin-Monahan
Hey Todd,
Sorry for the frustration on performance. I have noted that most people having performance issues are running H.264/HEVC 10 bit 4:2:2 variants. For now, I'll recommend using proxies or transcoding the original files. Please let the devs know you'd like this improved over on User Voice.
Vladimir21910480bw1m
Hello, I have another problem. When I shoot on my Sony A7S3 in 4k 120 4.2.0 on top of the frame maybe 1/3 from the frame have been completely unusable. The quality of this part of the frame is like 480 instead 4k. What should I do?  I attached files so you can see the bugs on the top of the frame. Please help me to find out how to do my job properly!
Just ran the file through Premiere on my Win10 24-core 128GB/RAM 2080Ti machine.
Image looked beautiful top to bottom. No "pixelation" or anything. There isn't a ton of fine detail in the trees far away of course, as they're both distant and somewhat out of focus. But that's normal for any image.
Okay....Thats interesting..... I have I9 processor and 1080Ti with 32gb of ram and even then I saw this "pixelation" on top of the frame. Can you render the file and send it back to me so I can see it. And thank you for your time!
 I appreciate it
I've just finished a project using the same camera and video specs and the playback was somehow sluggish, I've ended up using proxies to be able to work comfortably. My computer specs are a little bit low: i7-5930, geforce1080 ti, 64 Gb ram, win 10. Another thing: I noticed that PPro doesn't use hardware decoding when playing back those videos (needs support for that codec from Adobe?)
Kevin-Monahan
Hey Ali,
Sorry about that. Let the devs know here.
BROWNYJOHNY
I am a video editor. sony Fx3 4k 12fps footage I can't view in real time and can't edit at all. Can you please suggest a solution for this.
