Sony SLog3 to REC709 Which Preset LUT?
  • January 20, 2015
  • 71906 views
I'm shooting Sony FS7 Slog3 XAVC CineEI.
I'm looking to get this into a starting point and looking for a LUT for this. I note there are a number of manufacture specific preset LUTs available in Speedgrade. Has anyone out there been using Sony Slog3 and can recommend a starting point LUT in order to bring my gamma footage into the REC709 world?
Regards
    Correct answer RoninEdits
    there are "camera patches" in the looks for speedgrade but not sure which, if any would work. i do see some luts that come with davinci resolve lite that by name seems like they are for the F5 but might work. you can install the lite version for free, get the luts from someone who has it installed, or try the ones from the link below.
    C:\ProgramData\Blackmagic Design\DaVinci Resolve\Support\LUT\Sony
    SLog3SGamut3.CineToCine+709.cube,  SLog3SGamut3.CineToLC-709.cube,  SLog3SGamut3.CineToLC-709TypeA.cube,  SLog3SGamut3.CineToSLog2-709.cube
    there is also a post on sony's forums for what appears to be the same luts but perhaps older version.
    http://community.sony.com/t5/F5-F55/Release-version-3DLUT-s-for-S-Gamut3-Cine-S-Log3/m-p/287847#U287847
    Definitive SLog3.cine LUT workflow? - Sony's Community Site
    hello there.
    DaVinci Resolve (the newest free version) has the best Slog3 and Slog2 to rec709 converting LUT I have seen so far.
    Best.
    K
    RoninEdits
    RoninEditsCorrect answer
    FenlandACAuthor
    Thank you both. Yes, I am already a user of the Sony forum. Thanks for the links.
    I've seen commercially produced LUT's available for this, you'd need to search for them. Within Sg, there's the "Looks" produced by the "Lumetri engine" which are in application exactly the same as a LUT ... though they don't export to other programs. I know a number of colorists who've made their own Looks for specific cameras by simply loading test footage of a set scene or test pattern, then working their controls until they get the correct result in scopes, then saving that as a named Look for that camera.
    Doesn't take much time to do once you've the hang of Sg's controls. And that can be applied either within another layer or or on a separate adjustment layer made in PrPro for a grading layer.
