Sound and vision not in sync
  • August 31, 2024
  • 190 views
I wanted to re-edit some material with adobe premiere 2024, but suddenly sound and vision are not in sync.
How can I fix this?
Peru Bob
Check the Audio Hardware Preferences. Default Audio Input should be set to No Input.
Peru Bob
Please use the free MediaInfo and post a screenshot of the properties of your media in tree view:
https://mediaarea.net/en/MediaInfo
Many users are having issues with VFR. If the file is variable frame rate, use Handbrake to convert to constant frame rate before importing into Premiere Pro:
https://handbrake.fr/downloads.php
Here is a tutorial:
https://www.youtube.com/watch?time_continue=34&v=xlvxgVREX-Y
Shutter Encoder may also be used to convert to Constant Frame Rate:
https://www.shutterencoder.com/en/
