Sound problem within multicam sequence
Hello everyone,
when I create a multicam sequence (2 videos) with external sound I get performance problems. When I click in the timeline or set a cut it takes a few seconds (freeze, hang) until something happens or the program crashes.
This should not normally happen.
The waveform cannot be displayed via the multicam sequence (unless it is rendered).
If I flatten the sound in the main sequence, I don't have a problem.
What could be the reason?
Could it have something to do with the fact that Premiere has a problem displaying the waveform directly? Which component is responsible for displaying the waveform? GPU or sound card?
System details:
Win 10
Intel Core ™ i7-6850K CPU 3.60 GHz
Nvidia Titan X
All drivers are up to date
Best regards
Sebastian
