Aug 8, 2025 10:31 AM UTC
Sound running in Slow Motion
Hello!
I am trying to edit a video but every time I import the file and play it back, the sound is going at a super slow speed. I've tried three different versions of the file. I've tried putting it through media encoder (whole film and sound only). None of these things are working.
Does anyone have any ideas?
Peru Bob
Aug 8, 2025 4:13 PM UTC
If the solution offered by Ann Bens doesn't work, please use the free MediaInfo and post a screenshot of the properties of your media in tree view:
https://mediaarea.net/en/MediaInfo
Many users are having issues with VFR. If the file is variable frame rate, use Handbrake to convert to constant frame rate before importing into Premiere Pro:
https://handbrake.fr/downloads.php
Here is a tutorial:
https://www.youtube.com/watch?time_continue=34&v=xlvxgVREX-Y
Shutter Encoder may also be used to convert to Constant Frame Rate:
https://www.shutterencoder.com/en/
Aug 8, 2025 11:36 AM UTC
Make sure Default Input in the Audio Hardware in the Preferences is set to No Input.
