Jul 17, 2018 3:56 AM UTC
Speed/Duration % not inputting correctly...
I have several video clips in Premiere CC that I'm intending to speed up by 200%. I'm using the Speed/Duration dialog box to achieve this. I was able to make this happen with the first video clip, but the subsequent clips will not allow me to input the correct number.
Instead of displaying the percentage I type into the box (200% in this case), I'm seeing the same number each time: 2.59%. No matter what number* I input into the box, this is the result. Any additional digits I add are added to the beginning of the number.
For instance: Inputting 200% gives me 002.59%; Inputting 123 would give me 232.59%, inputting 0135 would give me 1352.59%.
* Correction: To further complicate the matter, this only happens when inputting numbers 0, 1, 2. Typing in any number 3 or above does not have this issue.
WHAT IS HAPPENING TO ME??
Robbinsfineart
Nov 21, 2020 5:46 PM UTC
Experiencing this as well.  Cutting the clips up into 30 minute segments solved the problem but this is new bug becuase I've always been able to speed up much longer clips without having to cut them up.  Premier Pro needs to fix this
olverart
Jun 23, 2020 3:02 AM UTC
And guess what, it is still hapennng in Premiere Pro 2020, when I try to change the speed / diration %, it gives me always 3.21 and if I add zeros, it adds the zeros before everything...
Jun 19, 2022 9:24 AM UTC
And same in 2022.... except I get 3.68% lol. Lucky I only do long clips like this every so often, annoying bug tho.
May 26, 2023 1:21 PM UTC
Still happening in 2023!! anything using 1 gets me a speed input of 1.91?!! have to drag the timeline duration to adjust the percentage.
Aug 14, 2018 10:30 AM UTC
I think I found a workaround by not using speed/duration but the Time Remapping parameter in the effect controls panel, when I set the parameter at 200% it stays at 200%.
Jul 17, 2018 10:44 PM UTC
I also experience this issue since several years now. Each time there is a new major update i hope this bug is fixed but it still with CC 2018.
It happens first when I have a clip with a dutation more than 30 minutes in the timeline. Link/Unlink several times speed/duration and finally i can enter the correct value or triming clip temporary to less than 30 min.
As you said it happens only when inputting values starting with 1 or 2. Entering 30% or 400% and it's Ok. Most annoying and strange bug i ever experienced with PPro.
NickstuffAuthor
Jul 18, 2018 4:03 AM UTC
I'm sure you've both got something, but I did find that once I chopped the clips into less-than 30-minute segments, I have been able to properly change the speed. Thanks!
Graeme Bull
Jul 17, 2018 4:37 AM UTC
That's weird.. I'd reimport probably. Check how the footage is being interpreted too just in case. With all that and maybe a restart or Premiere to be sure, I'd then just right click on the footage and show keyframes for speed and then adjust with that instead.
