Speed Issues in Premiere 2020
  • January 24, 2023
  • 86 replies
  • 1931 views
Any speed change that brings a clip over 100% speed results in choppy playback.
Major issue - doesn't just happen when speed ramping, but also shuttling at any speed beyond 100%! I just shelled out a lot of money for a new system so I can use CC 2020 and I have to downgrade to 2019 because of this. Hurry up Adobe and sort this out please!
Sadly still very much an issue a year later. How are these considered pro tools when they can't even do basic functions for a year?
GilSaigo
Nikolaos' solution works!
Disable hardware accelerated decoding and try again.
Thanks man
GilSaigo
Allow me to add that even when the playback seems to be ok (don't understand what affects this, but restarting the program sometimes works), the export comes out choppy. So frustrating!!!!!!! Come on guys!
+1 Please Fix Asap!
creophoto
The fact that this glitch continues to be left unfixed is truly shocking. Who is running the Premiere ship over there??
I´ve been using 2019 version since day one of 2020 release. Impossible to work with speed changes. Compained several times in adobe suppoprt chats and forums Here is a little video clip describing the problem. I am so gonna publish this on youtube. It is enough. No more fancy features updates no one uses. Correct what once was good and now it is wrong.
Speed ramping gets mixed frames playback. completely unusable.
SAME HERE!! when I change the speed more than 700%, the playback is very laggy ,choppy, showing mixed frames, GOD this really **** me off!!!
johnpooley3
