Sep 24, 2025 11:41 AM UTC
Spotlight index fails while premiere pro is running
Hello, I’m using the latest version of Adobe Premiere pro on a MacBook M3 Pro. After the recent update to macOS 26, Spotlight stops indexing files or finding any files as long as Premiere Pro is open. Once I close Premiere, Spotlight starts working again, and I can find the files.
I’ve checked the settings and contacted Apple, and they said this is an issue related to third-party applications.
What’s the solution so I can use Adobe Premiere normally and still access my files quickly via Spotlight? Only files, images, and videos don’t appear — other things like apps and settings still show up in search. As soon as I close Premiere, the files appear again in Spotlight
Adobe Employee
Sep 24, 2025 12:05 PM UTC
Hi there,
Welcome to the community! Spotlight search while running Premiere Pro on Tahoe 26.0 seems to be working fine at my end. Have you checked that all the required file types are enabled under System Settings > Spotlight > Results from System > Documents? Also, is this happening specifically with Premiere Pro v25.5 or with other Adobe apps as well?
Sumeet
Sep 24, 2025 6:07 PM UTC
Hi, yes i checked the settings
It's happing only when i use adope premiere once i close it everthing works fine
I tried with after effect and the spotlight works fine
Adobe Employee
Sep 24, 2025 6:35 PM UTC
Thanks for confirming that. Have you tried reinstalling Premiere Pro to see if it's making any difference, or checking any of the previous versions of Premiere Pro?
-Sumeet
