*SSD FAILURE: Damaged/Corrupted Premiere Pro Project. (HELP - Can anyone repair/fix?)*
Hello!
I had a Sandisk Extreme 2TB SSD fail on me.
Luckily it was a working drive and client's drive, but I didn't have my .proj files backed up to my personal file system.
I used Disk Drill and recovered it all, but the Premiere Pro .proj files are corrupted.
Yes I've tried:
- Opening up a new project and importing the .proj via both Media Browser and Command+I
- Viewing the .proj in XMLWrench - but nothing populated in the viewer. Blank text on every import
I know there is data somewhere in there because it has a file size of 7MB.
I also already contacted About Mohsen Aghaei - Adobe Support Community as he looks like he has had success, but he hasnt been online in two years.
Can ANYONE fix this .proj/XML?
File linked here: https://drive.google.com/file/d/1T-549LRbl4DCmkS4WLTj9rx1jN0zUyTs/view?usp=share_link
Working cut: https://vimeo.com/811451996/8afaf180c2
