Subclips inconsistent behavior; not always working correctly in Premiere Pro CC
  • June 24, 2013
  • 13 replies
  • 23496 views
I load a clip into the Source panel.  I set in and out points and then CTRL + U to create a subclip.  I have "Restrict Trim to subclip boundaries" turned off.  (Thank you Adobe, I've been waiting for "soft" subclips forEVER!)  The new subclip appears in my Project panel with the correct name and duration (as well as a white audio icon to indicate that it has not yet been used in my project).  Now, I drag that subclip into my sequence.  But the entire clip (a 5 minute interview), from which the subclip was derived, is loaded onto the timeline.
This has been working correctly for the last hour, and now it has stopped working.  It appears that for the moment, subclipping is dead to me.
Help?!
kit.kohler
This is unbelievable. Adobe, I generally understood you to have a stellar reputation for software, and I know the Premiere Team has been working to bring over FCP7 refugees, but WOW this is a huge, glaring issue with your software. Subclip management is one of the most important functions for most working filmmakers, and as far as I've been able to tell your development team has completely ignored this glaring issue for LITERALLY YEARS.
It's cute that you're making apps for smartphones and stuff, but how about you get your desktop software's basic functions working first before making apps to turn my vacation photo of the Eiffel Tower into a vector image on my Android, eh?
No response from Adobe. Just updated to 2017. Same bloody problem. Incredibly tight deadline with a workflow that I designed around subclips and this pretty basic feature only to discover on this tread it hasn't worked properly for years. ADOBE, take the frigging feature out of your bloody software if you can't be stuffed fixing it. Scumbags.
Maybe it is time we all started thinking about migrating to Davinci Resolve.
00kelly00
I am having this problem as well.  An hour ago, inserting subclips into Timeline worked, and now when I insert them, the entire clip is inserted.
I reset my preferences, restarted PP and same problem.  Please advise.
I'm having the problem as well.  The sub clip looks fine in the project window, but shows up in the source window or timeline as the entire clip
I am having a related problem, but can't seem to find any exact answer.  Everything is so inconsistent, and because I am a relative newbie, I cant tell if I am not using the product correctly, or there really is a bug.  I am making subclips from merged audio/video clips.  From some of the clips, I am making multiple subclips.  But for some of the subclips, the Hi Quality Audio does not come over, only the reference audio, which is really weird since I ticked the box that said "ignore reference audio".  Does anyone else have this problem?  Is it not correct to make multiple subclips from merged clips?
Thanks very much.
It is now January 2016 and I just installed Premiere Pro CC 2015.2 (9.2.0 41 Build), and am having this issue.
Hard subclips will import into the timeline properly, matching the in and out.  But soft subclips will import the entire clip into the timeline.  This problem occurs if I use the comma keyboard shortcut OR the Insert button on the Source panel OR right click and select Insert (or overwrite).  Basically any of the Insert or Overwrite commands trigger the problem.
However, if I use the mouse and drag the subclip from the Source panel to the timeline, the subclip transfers properly, respecting the In and Out markers.
So in my case, the issue appears to be with the Insert and Overwrite commands from the source window, including the keyboard shortcuts.  For some reason the issue does not occur when I use the mouse.
I'm interested to know if anyone else can reproduce these symptoms.  I'm open to suggestions, as the keyboard shortcuts are so much more convenient.
I just tested Subclips on a different machine, also running Premiere Pro CC 2015.2 (9.2.0 41 Build) and am able to reproduce the issue, with the same symptoms.
Created a brand new project, imported a video file, created two soft subclips from the same clip.  If I press comma from the Source window, the full 39 second clip is inserted into the timeline.  If I use my mouse to drag from the Source to the timeline, the 6 second subclip is properly inserted into the timeline.
So soft subclips do appear to work, but it appears that there is a bug with the Insert and Overwrite commands in the Source window that is causing them to improperly handle soft subclips.
Pieter Borman
I would just like to confirm what SW11 has experienced. I am having the exact same problem and will appreciated it very much of adobe will fix up the bug.
Is their a nice workaround this problem
I'm using CC 2015 latest version and this is STILL an issue. It's pretty pathetic. I thought they wanted this to be a professional tool? I hate getting those nostalgic feelings for FCP7. I want a modern editing system, but don't include features that don't work. Especially a feature that let's you organize hours and hours of footage and then have that organizing been worthless.
I've also been experiencing issues with subclips. I hadn't used them much until a large project I'm working on. I have more than 45 interviews that I've spent a long while going through and creating subclips, all of them with merged audio. When I open the subclip by itself in the Source monitor, it plays correctly. I cannot find a way to add it to the timeline without it moving to a complete new section of the original clip or the entire clip. I can't believe there's been a bug in the mix for over a year and a half with something as common as subclips and merged audio.
Similiar to Brendyeah, I am having the same inconsistent behavior with merged Subclips in CC 2014 latest patches on OSX. Brand new project. I create a subclip from a Merged video, when I drag it onto the timeline it's the entire clip, not the subclip, plus it has the red time markers on the edges of the clips (something no other Subclip has).
I need to get this job out the door so I can't spend time screwing with it. I'll just have to render the merged clips and re-import them as files so Subclips work properly. Seeing as this bug report was filed oh, 2 years ago, I won't hold my breath for a fix.
This is absolutely not a fix, but I found a work around that was faster than exporting and re-importing. Open the merged clip in the Source Monitor and set the in and out points within that window. You should be able to overwire/insert into the timeline using the keyboard shortcuts. I found mine glitched when I set the first point; it would zoom in on the Source Monitor's timeline. Zooming back out and setting the other point had no issues.
Again, insert or overwrite after BOTH points are set within the merged clip on the Source Monitor. Not ideal, but faster than rendering and importing.
I almost had to tell a client that a project was going to take twice as long, but the above workaround saved me from that. I'm saddened that Adobe has ignored a common problem for so long, but at least it's not completely useless.
I am having the same problem currently. I started a new project. I have Clips that are ProRess 422 merged with external audio. I was creating subclips of a longer piece of footage after merging it. When I double click on the subclip, it comes up as it should. However, when I drag it into the timeline, it shows up with the right duration, but the start time is just the begining of the clip, not the in point I marked.
Please help! I spent hours creating subclips, only now to find out that it was for nothing.
I also tried making subclips of NOT merged clips and it worked just fine.
If I can't get any help on this, I am going to export the long pieces of footage w/ the merged audio to create one clip with the video and audio I want. I will then relink the footage in the project, hopefully tricking it into thinking it isn't a merged clip.
Sorry, JLind.  Adobe doesn't think this is a problem.  I can't blame them, if they can't reproduce it.  My solution was to stop making Subclips.  Not a great solution, I know.  This bug has radically changed the way I edit video since 2013.  Subclips is simply not an option for me, when, as you correctly state, I could spend hours merging and creating subclips only to find out they don't work.  On a bright note, Audio Sync seems to be working *sometimes* now since 8.01.  So I use that to merge clips, but I just don't create subclips.
For a long interview (one that I used to chop up into subs), I use extensive clip markers to mark all of my key sound bytes.  I then use my marker window in a fashion similar to using a bin of subclips.  I find what I need, mark in and out and then throw it on the timeline.  Ideal?  No.  But it's become the norm for me for the last two years.
Now, if only clicking on a marker in the marker bin would set focus on that clip in the source bin...  We don't live in a perfect world.  Though it's not a super experience, the advantages of Premiere still outweigh the many bugs, so for now I stick with it.
Wow, that is strange. I put in a call to them as well. Maybe something will change this time around.
I found a work around as well. Kinda tedious but for what I was doing it worked well. I titled my subclips by question asked in the interview then made a new sequence from each one. I then copied and pasted the in/out points from my subclips to the original piece of footage (click on subclip, copy time code of in-point, click on original footage, copy timecode, then do the same for the out point) and put those clips into each sequence by itself. Now at least I know what I am looking at besides just "Interview 1." Definitely some draw backs, but again, it works for what I need it to.
hey kevin, thanks for the reply as well. the project was never used on ppro2014, if that's what you mean by updated.
after we updated to ppro2014 and all the bugs appeared, we uninstalled everything, cleaned with adobe cleaner and went back to ppro7.2.2. but I tested everything (mergeing and subclipping) on a brand new project and it's the same problem there.
our case was in technical support for weeks with no result, so I have no idea if this is caused by the app or our system...
I'm having the same problem: subclips from merged clips cannot be edited correctly. Also, my "Audio" synch option stopped working after we installed the new ppro 2014 version (along with many other weird bugs). We had to go back to the 7.2.2 version, and after finding out that we can't work with markers (because they can't save notes on merged clips), we logged everything with subclips and now these don't work either. Extremely annoying. I'm wondering: Is it such an unusual workflow to merge audio and video before editing? And is there still no workaround?
Kevin-Monahan
Hi onon111,
Is this a project you updated or is this a brand new project you're having problems with?
daxmacrog
And with version 8.1…subclips are still completely messed up. If I double-click on a clip in the timeline that came from a subclip, the source window displays the wrong portion of the clip with no way to move the playhead to the correct portion. And I mean no way to move it. It's stuck. You can't drag it. Hitting play causes the very beginning of the original clip to play, but the playhead still doesn't move. It's so completely buggy, it's hard to describe or even figure out what it's doing exactly. There's a weird gray bar that doesn't accurately signify anything. If I zoom the source window timeline out as far as it goes, I can see the markers for the in and out points of the subclip, but there is no way to get the playhead to them. If I make any attempts to adjust the in out points or create new ones, it goes completely wonky. The points don't correspond to anything visible.
I’ve lost track of the number of time I thought subclips were fixed only to lose hours work when I realized all the subclips I created were useless. I realize that I should just give up on using them, but if they worked, they sure would be useful.
Arghh. What I don't understand is that it's no even close to working properly. It's not some minor flaw that could go un-noticed. It wouldn't surprise me if it's a Mac-only bug, since there are an awful lot of those.
Kevin-Monahan
Hi Dax,
I tested out the Subclips feature in 8.1 and had some issues with a project I updated. I created a brand new project and markers are behaving as expected. Are you testing with a new project?
daxmacrog
Thanks, Kevin, for the reply. This is a new project, created after the latest update.
I am also struggling with this problem. Now I am prerendering the clips. Are there any news when it is going to be fixed or over workarounds?
I caught a rumor of a December update, but no data on what will be included.  (Or even if it's for PP.  It may be an AE update only.)
Mark Mapes
The issue detailed so nicely in Post #7 is fixed in the CC7.2 update. Thanks again to thepossibility for the great report.
