Subtitle issues - Not exported yet - how will it come out?
  • November 13, 2024
  • 1013 views
Hello everyone,
I don't get why Adobe put them all on different lines. So I only see them if I activate the 'eye'.
I'm a bit worried not all of them are going to come up on the screen, if I export? That is my main question.
DJWNAuthor
It didn't export 😞 even with everything on the same line.
Averdahl
Did you enable Captions for export? Captions are disabled by default, so checking that setting is critical for them to export.
  • What version of Premiere Pro do you use?
  • How do you export, from Premiere Pro or via Media Encoder?
I noticed that some of the of you captions are bright orange while some of the are dark orange. I cannot reproduce that in Premiere Pro 25.0.
Averdahl
I got carried away and just installed. It seems like my projects are okay but I did find I had to fix the subtitles on one.
Do the subtitles export now?
quote
By @DJWN
Averdahl
When i have done testings the only subtitles that exports are the ones on a track with the eye enabled. So in the screen dump you posted here only C3 will be exported. You can manually move all text from C2 down to C1, from C3 down to C1, C4 down to C1 and enable that track to export all subtitles in one go.
quote
By @DJWN
DJWNAuthor
Thank for this reply. I will test it out.
First, you can always test a short segment of a sequence, by setting an in/out point, and exporting. Then you know
Second, that 'eye' turns on the track. If on, it's 'visible', and will be in the export. If off, not.
DJWNAuthor
Thank you. I will try this.
