Sudden problem....bad lag....Insane lag when reversing speed of a clip... (with video)
Thanks in advance for any advice...
(video link goes to an unlisted youtube video on my channel and shows the lag...this was right after a full reboot.....the main timeline is laggy..(normally it is not)..but the footage of the rotating reel is even worse which is the reversed footage....(it takes about 5 to 8 seconds to pause after hitting the spacebar when playing) And things get worse as it heats up.
Everything was running fine for the most part (storage issues caused failed renders)......I decided after 2 years to start clean and reformat.....I rendered a few 4k 100mbps clips...without issue....(a little laggy on 240fps 1080p footage..which is normal)
But now.....it's unusable.
I tried resetting premier pro preferences.....tried unistalling and installing previous versions.
I tried numerous drivers for my chipset and graphics cards.
I can't figure it out.....(I went through all the checks on how to fix premier pro lag found on the internet)
(i never had to use proxy files....reset the media cache ((never tried changing it's location))
I have 30 gb of memory allocated to PP...never shows as using more than 25.....normally I kept 6gb on reserve...
I've run every test and auto updater to see if something was missing, malfunctioning, or overheating.
Parameters match numbers from last year.
(I use a cooling pad that helps some)
Dell xps 9560 laptop.
1TB ssd
32 gb ram
core i7 7700
gtx 1050
I found the video card is on the no longer supported list ..but that was last year...and I rendered 50 videos upwards of 2 hours long without issue.
https://www.youtube.com/watch?v=_RRnphNn4-E&ab_channel=TackleAdvisors
