System requirements have problem
  • March 24, 2018
  • 273 views
Somebody tell me My System requirements not enough for premiere Pro?
My Computer Windows 10 64 bit
Processor Intel i7 8700 K 3.70GHz Coffee Lake
Ram 32 GB
Mainboard Z 370sli plus
Bios A 20
Gpu NVIDIA GTX 1080 Ti
Disk C Samsung ssd 960 Evo 250 GB
Disk D wdc 2 TB
Just have a problem After 2 month
CPU Run 100%
In task Manager Adobe premiere Pro Run with wmi provider Host Used CPU 100%
In Memory Premier pro 9285 MB
In Program to slow Some Time error When I save project
I Try To solve the problem By using The Proxy file
Nothing Better
I don't know what the problem is with Adobe or Windows
I ask you before Maybe You can Help me
I Clear Cache Every Time ending project
    Vishu_Aggarwal
    Your System Configuration is very good...and premiere pro should work fine.
    What is the exact issue your facing. If you mean that Premiere pro is slowing down or not able to give real time Playback than you need to provide more details regarding the media, effects, sequence settings your using with premiere pro and also the version of Premiere pro your working.
    How much free space does C drive have available and is you media stored on SSD or HDD.
    Vishu AggarwalAdobe Certified Instructor, Professional and Expert
    mandicreally
    That system should be plenty strong for Adobe.  Beyond plenty strong.
    Is it just going to 100% any time you are working or when you try and do certain things?  Sorry I'm not fully understanding.
