The effects like opacity and position and scale are not showing up in the effect controls panel
  • August 5, 2020
  • 2003 views
When I go to the effect controls, it just lets me choose from time remapping volume Chanel volume
Correct answer JackSommers
It did not work
-Jack
Case closed, just had to download a new version of premiere
Post screenshot of what your are seeing (or not seeing).
You choose from the list, and yea, it can be sort of confusing.
 Basically work through from what, CC apps to Premiere to the specific Premiere. It asks specifically for permission to begin deleting things before it starts, so you can select options without fear ...
It did not work
-Jack
Look for an arrow to twirl open by “motion.”
There is no motion
-Jack
Sounds like you have 'scrolled down' the ECP. There should be a very faint scroll bar on the right side of the panel, use that or your mouse scroll wheel while hovering over the panel.
