TIME REMAPPING DOESN'T WORK IN PREMIERE PRO CC 2018
Dear All,
I got a trouble when using Time Remapping, After I click the Effect Badge on the Timeline then select Time Remapping, then move the fade out button, however the time remapping doesn't work, I cannot adjust speed duration by drag pointer, the line of the time still flat as per screen attached.
Please advise to solve this problem.
Thanks & B/regards,
