AntDX316
Time Remapping (Speed Ramp) and Lumetri Color (WB/AE control) is not synced.
  • January 31, 2020
  • 2180 views
When I have the speed control active on the same movie even blade clipped w/ or w/o, the Lumetri Color keyframing even at 100% speed throughout but speed ramped earlier in the video, the video and Lumetri Color are not synced.  It's super broken somewhere but it's not synced!!!!!!!!! Making it impossible to color grade.  Say you keyframe the lumetri color in a speed ramped video,  the place at where you want the adjustments do not adjust and adjust Later in the video given the speed ramp was slowing things down earlier.  Basically you are then trying to adjust for the some time in the future of where you are now making it crazy w/ test and tuning rather than being a direct precision time update.
I have the latest Nvidia studio drivers on a 2080 Ti.  Latest Windows 10 drivers and bios, it's not my PC.
I assume this is heavily overlooked as people who do even speed ramp and other things prefer AE but the blade cutting isn't as simple direct as Premiere making it difficult to mind flow due to the user technical hurdling.
I'm trying to satisfy balance the blacks and shadows because I didn't WB/AE lock.  If the video has no speed time ramps, you can fix this by adjusting the keyframing of the Lumetri color so it doesn't go super bright to dark or dark to super bright.  It stays nearly balanced.  When you have speed ramps in the video, the sync is non-existent and it's like the lips and the audio do not match.
When applying multiple complex effects ... and both Lumetri and ramps fill the bill ... it is best to do one of two things.
First, 'nest' after say Lumetri, then ramp, or the other way around.
Second, do one, perhaps Lumetri. Do a full render & replace to bake that in. Then do the ramp work.
These will probably work fine. It's simply the practical way stuff gets done.
Thanks Neil, I'll try as you say.
I kind of sorted it out by cropping the speeded line and adjusting Lumetri in each of the crops. It was a long video in which exposure changed during the filming and, once I speeded it up, any of the Lumetri effect controls worked to adjust the exposure variation.
A thing that I couldn't solve was making the decreasing speed ramp work at the end of the speeded section. I tried without using Lumetri or any other effect and it still doesn't work. Any hints on this? Thanks for your support 👍 It's very much appreciated.
Speed ramping is a particularly intriguing process all by itself. I don't do it nearly as much as many others do, and so every time I'm having to remember how to do it.
It's particularly difficult to nail getting say a gradual to fast speedup that comes to a sudden 'freeze' correct.
And there are better people around like @Warren Heaton10841144 or others for advice on this technique.
I've got exactly the same issue. Has anybody solved this? It makes it impossible to use time remapping because you can see the different gradings from far.
Also, another thing that I couldn't do was to add a decrease speed ramp at the end to merge the fast/slow footage smoother 🤔 🤔
What's happening? These are very basic features. I work from a Macbook Pro intel i7.
