Time Remapping (Speed Ramp) and Lumetri Color (WB/AE control) is not synced.
When I have the speed control active on the same movie even blade clipped w/ or w/o, the Lumetri Color keyframing even at 100% speed throughout but speed ramped earlier in the video, the video and Lumetri Color are not synced. It's super broken somewhere but it's not synced!!!!!!!!! Making it impossible to color grade. Say you keyframe the lumetri color in a speed ramped video, the place at where you want the adjustments do not adjust and adjust Later in the video given the speed ramp was slowing things down earlier. Basically you are then trying to adjust for the some time in the future of where you are now making it crazy w/ test and tuning rather than being a direct precision time update.
I have the latest Nvidia studio drivers on a 2080 Ti. Latest Windows 10 drivers and bios, it's not my PC.
I assume this is heavily overlooked as people who do even speed ramp and other things prefer AE but the blade cutting isn't as simple direct as Premiere making it difficult to mind flow due to the user technical hurdling.
I'm trying to satisfy balance the blacks and shadows because I didn't WB/AE lock. If the video has no speed time ramps, you can fix this by adjusting the keyframing of the Lumetri color so it doesn't go super bright to dark or dark to super bright. It stays nearly balanced. When you have speed ramps in the video, the sync is non-existent and it's like the lips and the audio do not match.
