NikiWin
Time Remapping/Speed Ramps
  • January 12, 2018
  • 5 replies
  • 11698 views
I have a important question! How can I copy the keyframes of the time remapping, when I hit CTRL + C and move forward and then press CTRL + V then nothing happens, even when I rightclick the keyframes and click copy and then I click paste nothing happens, please help, I don't want to make so many speed ramps per hand!
MyerPj
I didn't see @Wenda24817131qk0b 's post to just now, but my suggestion would have been strongly to move it to After Effects. Anyway, if you can do that, it's so much nicer for these type things. Anything beyond a simple / straight-forward time-remapping should be seriously thought above in AE. It's there in CC package and is well worth looking into.
i had the same problem 2024, and i tried nesting the sequence first and the pasting the speed ramping or time remapping it after, it worked for me.
When I tried to combine a bunch of ajustment layers (with the same speed remapping effect on all of them), and nest them together, it combined all the clips together, but just deleted the speed remapping effect. Can you explain how to you got time remapping to work when nesting a bunch of clips, then copy pasting them to the video?
Where are you trying to copy and paste them? If you're doing it in the timeline you might want to do it in the Effects Control panel.
remia31450070
Click right on your clip, select "Copy". Then, click rigth on the copt you want to paste the time remapping, then select "Paste Attributes", and keep only "Time Remapping" selected. Click "OK" and you're set.
ivanc40861895
when I click to paste the attributes and select "time remapping" the movie is changing the clip lenght for the same duration Of the clip that i has copy the attributes (not only the speed as I Did for 10000 before).
sorry for my bad english (I'm Brazilian)
oh so you are saying that it USED to work! i'm very new to adobe premiere so don't have that historical background but so it seems like a recent bug then.
i don't think we can do anything really 😞 -- is there a mechanism to report bugs? this isn't a feature request necessarily if it used to "scale" the keypoints to the clip you pasted it onto.
It is 2023 and this is still happening.  I can't even imagine a use for copy and paste attributes with regard to time-remapping where I would want each clip to set a new in-point and make them all the exact same duration.  USELESS.
premieregal
I don't think there is a way to copy and paste time remapping key frames, unfortunately. I think this is because each keyframe relates to the time in which it starts on the timeline. Here is a tutorial on time-remapping:
