Timeline Glitch (M1 Max) & Import Error
- May 29, 2022
- 4 replies
- 2406 views
Two errors I'm finding tonight (I think the timeline one is from the most recent update)
Timeline Error:
When editing in the timeline after a bit randomly the timeline will start to glitch drastically. If you're also trying to move video or audio onto another track it doesn't visually move. To get rid of this glitch if you open another window (Say finder, or an internet browser, etc) the glitch fixes itself and works for another 5-10 min before randomly doing it again. Only noticed this on my M1 Max Macbook Pro.
Import Issue:
This seems to be new too. As I'm using the new import menu, I select "Video only" and click on my a1 folder from Day 1 which has a few cards I've offloaded. It imports the video perfectly, but still imports the Jpeg images from the thumbnail folder. Pretty annoying. Also, you cant select the directory viewers as everything is greyed out.
