Title not showing up in timeline
  • August 18, 2017
  • 13356 views
    maneesh konkar
    Hey guys I figured out what waas happening. It was there on Track V4. just minimize tracks V1 to V3 and you should see it right there on V4. hope this helps. Thanks
    Ahh ... an older version. And as you have no text, I had to look at this for a bit to puzzle out what your problem probably is.
    I've not worked CC2014 or earlier in some time, as this clearly is ... but I'm thinking back and wondering if you have yet 'closed' the Titler window? I think that was what essentially "saved" titling done in that window back then, so that it would appear in the bins and was usable on the timeline.
    MontuckyAuthor
    I tried closing it and re-opening with no success.
    Stan Jones
    PLEASE Do not post personal information!!!!
    Ann moderator.
    The title has the wrong aspect ratio (its not the same as the timeline). That is why you are not seeing it.
    Gabe, if you are responding via email, turn off your auto-signature. It is posting all your personal information on a public website.
