Unable to cut/trim sequence at specific point, Adobe Premiere Pro CC 2018
- April 21, 2020
- 1 reply
- 5473 views
- As the below video shows, I want to cut my project at the start of the marker, but I'm unable. If I try to drag the clip it says 'minimum trim duration reached on video 1'.
It's the first time I've experienced this issue and it's driving me crazy... I really need to do some precise clip editing!
My video is portrait and not my usual landscape, would that be an issue? Thanks, Tommy
