Using an adjustment layer to create a mask
- January 8, 2022
- 3 replies
- 684 views
I am trying to create a mask using an adjustment layer.
The image I have attached shows 3 layers
The top layer is the adjustment layer, I have created a mask on this layer
The middle layer contains words, these words start small and then grow in size
The bottom layer has a picture of a box. I am trying to use the mask on the asjustement layer to match the edges of the box
When the words grow/scale to a size they begin to exceed the edges of the box/mask I woud like the part of the words outside the box to not be visible.
I have not been able to use an adjustment layer to mask anything.
Is what I am asking possible? Am I making a mistake?
