Using Anamorphic Footage and Spherical in same project?
  • September 17, 2020
  • 676 views
So if I make the project frame size is anamorphic, my spherical footage with be surrounded by a square, but if I have the project frame size for my spherical footage, my anamorphic footage will be punched and and not the true anamirphic ratio. Does anyone know how to get around this? Thanks! 🙂
ElDoggoAuthor
Already figured it out lol.
My fix--- I just used my typical spherical frame, and when anamorphic footage is in, I went to effect controls, motion, and scaled it down until the edges fit perfectly.
I just right click the anamorphic footage in my timeline and click "set to frame size".
