Using Korg NanoKontrol Studio for audio with Premiere Pro 14.1.0
Hey everyone,
Having some issues here. I found a tutorial on YouTube where a guy was able to get Korg's NanoKontrol Studio mobile MIDI controller to work as an audio mixer control surface inside Premiere. The process seemed straightforward, so I went ahead and ordered one.
Once I have the controller booted up in Mackie mode (set + rec button + turn on), I go into my control surface preferences, where "Mackie" is listed under Device Class. I click on it, and click the edit button under the window. Then I click settings on the window that pops up, then I click Mackie Control, then Edit, and under MIDI input and output devices, the NanoKontrol Studio is listed. So it seems that Premiere is recognizing it.
Only it doesn't control anything. The jog wheel doesn't work, nor do the faders or pan knobs. Not sure what I'm missing here.
