Video with inherent grain/noise looks fine in file, but has artifacts once uploaded -- better export settings?
  • August 11, 2017
  • 462 views
Hey all,
Working on an experimental short film that has a high grain content as part of its aesthetic. It took a little trial and error, but I got it to come through clearly on export, but once I uploaded it to Youtube and Vimeo it started showing artifacts.
Here's what the file itself looks like:
And here's what it looks like on Youtube (1080p) and Vimeo:
Export settings are as follows:
Format: H.264
Preset: Youtube 1080p HD
constrained to 1080x1080 (original file size)
VBR 2 Pass at highest possible target bitrate + maximum bitrate
with "Use Maximum Render Quality" ticked
Original files are just static pngs which I manipulated using premiere's effects.
Is it a fool's errand to try and get this to look clean on streaming sites or am I missing something in the export settings?
If you upload to Youtube the file will get re-encoded.
The noise will get worse.
Uncheck MRQ if you have a MPE hardware.
Might want to up the bitrate.
The bitrate is already at maximum, but I'll uncheck MRQ and see how that goes. Though if I'm understanding you correctly, it probably still wont work because Youtube will re-encode it.
Thank you
