Videos and sound keep lagging + double speed
Hi
I just installed the test version of Premiere Pro 2017 to help me make a decision for a video editing program.
I have the problem that imported clips stutter heavily when starting the playback. This problem happens in the media preview window but also
for clips in the timeline, even after I rendered the sequence. The sound also sounds horribly distorted. It looks like the video would jump back a few frames periodically.
Additionally, all clips run with about double the speed they should. It doesn't depend on the used material, i tested GoPro footage with different settings but also the Windows example video (wildlife).
What i did:
- Create a new project
- Add a new sequnce with the AVCHD 1080p-60fps setting
- Import the footages (mainly GoPro 1080p, 60fps clips)
My System:
i7 2700k @4GHz
16GB RAM
nvidia GTX780
Windows 7 64 Bit
Has anybody any ideas what the problem could be? I would greatly appreciate any tips that could help me to solve this.
Thanks.
