Cbohlender2003
Virtual Production on LED Wall. Split video output on to two separate monitors.
  • December 8, 2022
  • 910 views
Thanks in advance for any help you can provide.  We are using Premiere to display a video on a LED wall.  It's 40 ft long and 12 ft high.  The resolution is 4752 x 1296.  Because it's two 16x9 signals, we need to output the video to two separate monitors and combine the signal on the LED screen.  I need a software solution to split the video out from Premiere into two separate signals, with each signal/screen displaying half the video image.  Confusing, I know...  See images of the out wall for reference.  I'm hoping there is a plugin for this.
Averdahl
quote
By @Cbohlender2003
Maybe one of the Video Wall Products from Video | Matrox will do the trick.
I would have started there.
