Voice Over Recording in Premiere Pro CC 2019 doesn't work
  • October 19, 2018
  • 38 replies
  • 39352 views
Does anyone else have this problem? I want to record a voice-over and it doesn't work. I checked the internal audio settings of my new MacBook Pro as well as the internal software settings of CC 2019. Both show the VO Mic. And while I see the sound get into the laptop I don't get any audio levels in Premiere. When I tried this with the older version CC 2018 it worked as it always has. Does anyone have a fix? Do I need to install a new plugin? That would be strange, because in the VO record settings it shows that it recognises the mic...
Thanks for your help!
Correct answer Meg The Dog
Just a quick check - if you go to System Preferences > Security & Privacy,  Click on Microphone in the left sidebar and verify Premiere Pro 2019 has access ( is checked).
MtD
I have the same issue but in Windows 11. Everything is updated, all permissions granted (when I right-click on the microphone on the soundtrack, the window shows my microphone and when I talk into it, it shows it working- Sometimes, like once every 10 times, it works.)
thanks! - my headache suddenly disappeared
So i put in My sistem preferences my microfon as well in my mac imput and output but it won't record the audio, it shows the mic is avaleble to use it, i click on it to record I wait 3 secods like it says then it says is recording but when i pause it but it doesn't record anything, I don't know what to do. Help please
i know my mic is good because i use in another app and works fine buy im adobe it doesn't
Hey I know this is marked as solved but I figured out something I haven't found anyone online saying. So, I followed every advice and still no shot.... So I figured out the problem. If I create the project in an ssd it does not create the audio file after I press "stop".. So I created a project in the main sdd computer and it worked fine!  Maybe there is a way to circunvent this but I haven't found any. If you know of any please say so 🙂
Hope this helps any lost souls like me 🙂
Bless you.
THANKS!!!!!!  It works!
Michael L at UNCP
Live saver. Thanks. We had checked everything BUT mic permissions in preferences. That fixed it.
Wow, a big fat Thank you. I would have never thought of the privacy and security panel.
You guys just saved me with this , man I have been searching to the answer for this for a while. Thanks for posting this
Wow, this saved my life. I had uninstalled and reinstalled Premier TWICE! thanks so much!
