Volume Audio Effect will not stay in my custom "Favorite" effects folder. Disappears after restart.
  • August 28, 2023
  • 222 views
Premiere v23.6
Mac Pro Trashcan - Monteray 12.6
In the EFFECTS window, I have all my favorite effects collected in a "FAVORITES" custom folder. It all works perfectly exept for the "Volume" audio effect. For some reason, everytime I restart Premiere, the "Volume" effect disspears from my custom folder and I have to search for it again from the Audio Effect folder. It's quite an annoying bug as "volume" is probably one of the top three effects i'm contantly reaching for.
Correct answer jstrawn
This has been verified as fixed using the latest Public Beta build - Pr24.1 Beta 002.
The Balance, Mute & Volume effects placed in a custom Bin in the Effects panel now persist after close-re-opening the project.
You can try it in a current (Pr 24.1) Beta build, or wait for the 24.1 Public Release and let us know how it works for you. Thank you for reporting it.
Thanks!
jstrawn
jstrawnCorrect answer
Ron Rigler
@silvershanks this issue should be resolved with 24.1 beta 2 or later.
