Volume slides changing automatically in Audio Track Mixer
  • June 22, 2023
  • 4 replies
  • 782 views
I have 3+ audio tracks in my Audio track mixer. However, when trying to adjust the volume on any given one either via the slide or inputting a volume number, it just slides right back up to where it was prior to adjusting it. Is there something toggled on that is causing this? Thanks
In the Help docs Kevin posted, pay attention to the track Modes ... read/write/touch things.
That's often what is the issue here.
Also, are you adjusting while playing or while paused?
Hi @sarah262122157gqr,
I read your note. It appears you are having trouble with keyframe automation for audio. Can you review the Help doc and let me know if it is still operating strangely? https://helpx.adobe.com/premiere-pro/using/recording-audio-mixes.html I hope the docs help shed some light on the problem. Hope the community can help. Sorry for the frustration.
Ke
Hey Kevin,
I've attached a video of what's happening. I started by normalizing all my audio peaks to -6 dB. Then I when into the track mixer to adjust the volume on each audio track. As you can see the volume slider is all over the place without me even touching anything. I tried to remove all the audio attributes from the clip which didn't work, and further, when going back into the clip all the audio attributes i just remove had seemingly returned. Let me know if you have any ideas on what is going on here. Thanks!
https://youtu.be/7TlQqd-g36s
Hmm. The video is no longer there, @sarah262122157gqr - Any way you can upload again?
