WHAT HAS HAPPENED!!! Prem Pro Update
  • May 29, 2024
  • 4 replies
  • 589 views
Out filming the last two days, come to edit and premiere pro has auto updated - RUINED THE COLOURS, and completely ruined playback. Spoken to other pro editors who use Prem Pro and they are having the same problem. Absolute mess. Hopefully they can fix this ASAP.
Hi! Thanks, lwwilde!
I was worried I was alone in the playback issues, and have found other threads from 2018 with the same problem and not much of a solution, as the solution used then is no longer possible with the new update- I haven't been able to import my project into a new file at all.
Good luck, hope Adobe responds!
Update! Changing the label colors to classic has fixed my playback issues after re-installing premeire, for some reason!
lwwildeAuthor
I have read through this thoroughly - doesn't explain the awful colours and ruined playback. I can't even watch the clips anymore.
