Klintberger
When can I use two screens again?
  • February 6, 2025
  • 4 replies
  • 641 views
I edit in Premiere Pro with two screens, very handy and useful. But two days ago this wasn't possible anymore. I couldn't move clips on the time line on of the screens.
I contacted Adobe and the support worked on it but couldn't help solve this issue. The problem was due to the latest update of Windows 11, Adobe said. The support gave two contradictory answers:
  1. We have to for a new update by Windows,
  2. Adobe is working on this problem and will solve this in the next version of PP. "This will take some time", Adode informed.
    Does anyone by chance have a clue how long time this will take or could Adobe answer this question?
Correct answer Klintberger
Hi Kumar!
Adobe contacted me and suggested this solution: uninstall the latest update from Windows KB5050094. I did and it worked!
Hi Klintberger,
We're sorry about the poor experience. We're investigating a similar issue. Could you please confirm the exact version of Windows you are using & the resolution and scale % of both monitors? For testing purposes, please try moving all the Premiere Pro panels & Workspace to the primary monitor to see if you are able to move clips on the timeline. Let us know if it works on the primary monitor.
Sumeet
Klintberger
Hi Sumeet.
I'm using Windows 11  24H2.  The scale of both monitors are 100 %. What is resolution? I have moved all the panels & workspace to the primary monitor and it works there. But now all of a sudden another difficulty appears: the function with link/unlink, group/ungroup, doesn't function any more.
Make sure your graphics card driver is up to date.
Reset workspace and or Reset Preferences.
See how that goes.
Klintberger
I found a text in support how to reset and restore preferences.
Moved from beta to regular forum.
jane-e
@Klintberger
I've moved your post from Using the Community to the Premiere Pro forum.
Jane
