ajfilms
When is enough enough? Serious long-term stability problems across versions (2016–2025)
I
I’ve been editing for 20–25 years. I came from Final Cut Pro 7, which I used for a decade without major failures. I moved to Premiere in 2016 because I liked the classic layout and viewer windows. But the truth is simple: Premiere has never been as stable for me as FCP7 was.
Adobe engineers have always been kind and helpful, and this isn’t about them. This is about repeated instability across version after version. I’m not changing my workflow. I’m not changing how I build sequences. I’m not doing anything unusual. I’m shooting weddings and corporate work with normal cameras and normal codecs.
Yet every major release—16, 18, 24, 25—breaks something that worked in the previous version. When 24.x.6 or .7 finally becomes stable, 25 introduces new issues. And somehow, the default response is always that the user did something wrong.
Below is a list of problems I’ve dealt with over the years on top-of-the-line Mac Studios, clean installs, clean projects, and standard workflows:
Long-term recurring issues
  • Lag on simple H.264/H.265 timelines
  • Multicam drift/desync after reopening projects
  • Render bar switching colors at random
  • Audio drift on long speeches and ceremonies
  • Memory leaks that require restarts
  • Exports failing until Premiere is restarted
  • GPU acceleration shutting off
  • ProRes footage stuttering
  • Projects crashing only on certain versions
  • Color shifting on export
  • “File is busy/in use” errors
  • Proxies disconnecting
  • Nested sequence instability
  • Older projects unreadable unless opened on their original version
  • Media pending freezes on basic footage
The latest problem: Warp Stabilizer is breaking Premiere
I rely on Warp Stabilizer constantly for wedding films. In the current version, using it causes:
  • Black frames
  • Missing frames
  • Random flashes
  • Broken stabilization
  • Glitches when scaling or repositioning
  • Black frames when dissolves overlap stabilized clips
  • Render errors triggered only when Warp Stabilizer is applied
This is a basic tool, not a niche plugin. It has failed across several versions.
The bigger question: why does Premiere struggle with footage every other NLE handles without issue?
This is the part I can’t overlook anymore.
There are other editing programs—Final Cut Pro, DaVinci Resolve, even free versions—where you can drop:
  • iPhone H.264
  • iPhone H.265
  • DJI footage
  • DSLR native footage
  • Mirrorless native footage
  • Osmo footage
  • Whatever you throw at it
…and it just plays. Smooth. Instantly.
No lag. No choking. No excuses.
I’m paying for maxed-out $14,000 Macs because I expect fluid editing. Yet Premiere still struggles with basic camera-original clips. FCP (a one-time purchase) plays them perfectly. Resolve plays them perfectly. Meanwhile, Premiere stutters, hangs, or lags for reasons I can’t justify.
I understand codecs. I understand long GOP. I understand proxies.
But none of that explains why one version of Premiere runs flawlessly and the next becomes unusable on the same hardware.
This isn’t a workflow problem.
This is a foundation problem.
Where this leaves me
I can’t believe I’m saying this, but I’m genuinely considering leaving Premiere within the year. Not because I want to—but because I’m exhausted. The instability slows my work, and I don’t have the luxury to take a month off to relearn Resolve or the new Final Cut ecosystem.
The sad part is that Premiere’s stability issues are now overshadowed by a constant push for new AI features that don’t fix the core editing experience.
AI is not helping me stabilize a clip without black frames.
AI is not helping my H.264 footage play smoothly.
AI is not fixing long-standing bugs.
It feels like the basics are being ignored.
My question to the community
Has anyone else reached this level of frustration?
Not one-off bugs.
Not random crashes.
But years of the same foundation problems across new versions?
If you’ve dealt with similar issues—or found real solutions outside the usual “try proxies, try resetting preferences”—I would appreciate hearing your experiences.
Thanks for reading.
Sounds like a mess, but no, I've not had anything like that recurring behaviour you've had, and am on PCs. I've been working with Pr since CS6 days, just prior to the original CC version. Occasional hiccups, but nothing like you're getting. Just ... wow.
