Why does Premiere Pro 25 keep conforming the same audio clip everytime i open the project?
Everytime i open peremier pro projuct it conforms the same audio file no matter how many times it has been conformed before. Any ideas or solutions?
mattchristensen
mattchristensenCorrect answer
This can happen if the media or the media cache is set to a server and there is a time difference between your computer and the server's clocks and timestamps. First, where is your media cache set to – local to your system? You can check in Preferences > Media cache. Second, is your media living on a server, and are you able to check the clock of that server?
mattchristensen
aliz23Author
Thank you! The original media and cache both live on the QNAP which i access from different computers. I checked and set the QNAP time to match my systems and it worked!!
