Why my audio volume is way higher in AE than in Pr?
  • October 7, 2024
  • 239 views
I have some footage with audio that plays quietly in Premiere (I have to raise my Mac volume at ~90% to hear comfortably), but then when I replace parts of it with AE compositions, the very same clips play very loudly in AE. Due to this, I'm hurting my ears quite a lot because I forget to lower the volume when I switch to AE.
I want to point out that there are no effects applied to the audio of the clips, nor to the tracks in the Audio Track Mixer in Premiere.
Can someone help me understand what is wrong and how to avoid it?
Pr v24.6.1 (Build 2)
AE v24.6.2 (Build 2)
macOS Sonoma 14.7
Media file properties:
Type: MPEG Movie File Size: 28,75 GB
Image Size: 3840 x 2160
Frame Rate: 25,00
Source Audio Format: 48000 Hz - 16-bit - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:28:36:00
Pixel Aspect Ratio: 1,0 Alpha: None
Color Space: Rec. 709 Color Space Override: Off
Input LUT: None
Video Codec Type: MP4/MOV H.264 10 bit 4:2:2
Does the audio play louder in the Footage panel in After Effects, or just in the composition?
Do you mean in the individual layer tab? It plays at the same volume both as a layer, and in the containing composition.
