Hybrid Forward Video
Workflow of audition and on a multicam.
  • August 16, 2018
  • 320 views
I have a question about the correct workflow to tidy up audio in Audition for Multi Cam. I assume that after new sequence from the multi cam timeline I can do some post in Audition but it seems to be greyed.
What's the correct workflow?
    calebwojcik
    My workflow for multi cam sequences into Audition is to just select the all the tracks (including the multi-cam tracks) and select "Edit Clip in Audition".
    You just can't click on a sequence in the project browser to go straight to Audition when it is multi-cam'd.
    Another option is to flatten the multi-cam sequence. Then you'd be able to.
    Hope that helps!
