vladimiri14843118
Zoom does not work at values greater than 100%
  • February 26, 2020
  • 196 views
[Profanity removed]
Is this release? Really?
Moderator Note: Please do not use profanity here, even if implied. We have minors reading here. Thanks!
Peru Bob
Try resetting the preferences:
https://community.adobe.com/t5/Premiere-Pro/FAQ-How-to-reset-trash-preferences-in-Premiere-Pro/td-p/8236158
Reset a workspace
1. Do one of the following:
• Click the Workspace menu icon and select Reset to Saved Layout.
• Choose Window > Workspace > Reset to Saved Layout.
from here:
If that doesn’t work, try updating or rolling back your graphics driver directly from the video card manufacturer’s site.
It's working just fine here. That sort of image on screen is nearly always a video driver issue with the GPU, or some problem in that area of the computer. So my guesstimate is the newer verion of Premiere needs an updated graphics driver for your GPU ... or updated GPU. Not knowing what you have.
