Videographer Suxrob
Premiere Pro CC2022 Problem Sapphire Plugins
  • August 12, 2021
  • 2095 views
Hi, I am translating using google translator, I apologize for grammatical errors.
I downloaded the Beta version of Adobe Premiere Pro CC2022, there is some flicker in the videos when I play the videos after installation, this is often very noticeable when I put the panorama shots, the 2nd problem is Ctr + Alt + Shift When I reopen using Sapphire, the video transitions go to the video effects section, and re-installing Sapphiere (2021_51) still doesn't solve the problem, What should I do?
OS: Windows 11 Pro
Cpu: Core i9 9900K
Gpu: RTX 2060Super Game reader driver
Please help me solve my problems.
Correct answer Bruce Bullis
I had already watched the video. 🙂
To pursue the issue further, we would need:
  • Any projects and media files necessary to reproduce the issue
  • Specifics about any additional plug-ins or extensions necessary to reproduce the issue
  • Step-by-step instructions which reliably reproduce the issue.
Bruce Bullis
Confirming: With some clips in some sequences with some Sapphire effects applied, you see flicker when rendered in PPro beta, that you didn't see in PPro official release? If so, we'd need to know which effect(s) you mean, and get step-by-step instructions on how to reproduce the behavior.
You say "the video transitions go to the video effects section"; PPro organizes plug-ins based on the information they provide to PPro, when being loaded. If Red Giant's effects moved categories, then Red Giant made that change.
Videographer Suxrob
Do you work at Adobe? So can you remotely access my computer and see the problem?
Bruce Bullis
Yes, and no.
We are happy to pursue issues further, provided:
Videographer Suxrob
Can anyone answer?
Please ...
Videographer Suxrob
