Nick Lear
Productions - focus doesn't stay with source when cutting from one project to another (sometimes)!
  • June 19, 2023
  • 555 views
As long as you haven't chosen to switch focus to timeline in prefs, you should be able to cut from a source sequence that's open as a timeline to another timeline, without focus switching away. Currently (and in previous versions) the focus sometimes switches to the project panel for me, when the source sequence is in a different project from the program sequence. Not always though, so that makes this a harder solve.
I can't see how to reproduce this consisently or avoid it consistently. But it does lower procuctivity.
Pr 23.6.0.19 beta
mattchristensen
@Nick Lear yeah that other issue you describe is a different symptom of the same issue. It is fixed now in the Beta version, 24.0 build 007 or later.
Nick Lear
Nick LearAuthor
Thanks Matt
mattchristensen
@Nick Lear Thanks for this report. I can see what's going on, and I'll get a bug logged on this.
Nick Lear
Nick LearAuthor
Awesome, thanks @mattchristensen
Nick Lear
Nick LearAuthor
I'm getting a what I think is connected thing, which is that when I cut and paste in a timeline that is full screen (i.e using the the ~ key), the full screen-ness goes away and the project gets highlighted.
Pr 23.6.0.27
