Resizing Clip After Using Enhance Speech Causes Audio Echo
Premiere Pro Beta 24.1.0
PC - Windows 10
After I've applied the new Enhance Speech effect to a clip, resizing it will cause the audio to echo, almost as if the audio track is duplicated and out of sync with itself.
It happens whether increasing or decreasing the time.
The only solution is to close and re-open my project.
The audio track I'm using is mono.
