Surface Control issue
  • November 19, 2020
  • 267 views
The use of control surfaces is impossible, for operations for example adding tracks, changing fps to the working sequence, leads to ppro freezing. I use the eucon protocol, but the others have the same problem.
 In the latest version, the controls no longer appear in the list, but this has already been reported.
System info
    Application: Premiere Pro (Beta) v14.7.0.18
    OS: Windows v10.0.18363, RAM: 47.93 GB, CPUs (logical): 16
mattchristensen
This is a known issue and has already been fixed in the more recent beta versions. Please update to the latest Premiere Pro (Beta) v14.9
Hi Ovidiu Bob,
anything new according to the the use of Eucon protocol? (I use it with avid artist mixer, worked perfectly fine past 5 years). In the latest updates of premiere it's impossible to use a control surface. When mixing it works, but when I want to make a cut after mixing , PPro freezes. And I am able to repeat the freeze..
Premiere Prov14.7.0 build 23
mac os x 10.15.7 Catalina
iMac (Retina 5K, 27-inch, 2019)
Processor Name: 8-Core Intel Core i9
