Jan 26, 2015 11:08 AM UTC
.CHM help compiled using RHCL differs from same help compiled using RoboHelp GUI
I am using RoboHelp HTML 11.0.3.268.
My project uses graphics for list bullets in headings, set in the .css, as in the following example:
     h2 {
          list-style-image: url("img/black.png");
When I view the help in the following scenarios, the graphics are displayed except for when the help has been built using RHCL:
  • Previewing the topics in RH displays the graphics.
  • Opening the topics in a browser (Firefox, Chrome, or Internet Explorer) displays the graphics
  • Compiling the .chm file in RH using SSLs > Generate displays the graphics.
  • Compiling the .chm using RHCL uses ordinary round bullets instead of the graphics.
Any ideas, please, how I can create the .chm in an overnight script with the graphics for bullets instead of the round ones?
Andy
Jan 26, 2015 1:42 PM UTC
I've completed a bug report
Peter Grainge
Jan 27, 2015 10:45 AM UTC
Meantime try putting your headings into a two column single row table with no border. Image in one cell, text in the other. That used to overcome a similar problem.
See www.grainge.org for RoboHelp and Authoring tips
@petergrainge
Jan 27, 2015 10:51 AM UTC
Thanks for the suggestion, Peter - that would be a good way to avoid the issue.
